1 - 10 of 10 Posts
It'll feel better after it quits hurtin...
Other than reading and following the owners manual instructions can you give me any advice as to the proceedures, break-in oil type, etc. that can help me insure a good long life for my new Yamaha?
Thanks in advance.
Qwners manual says it all.
One bit of advice...invest in a OEM shop manual,
if you plan to do your own repairs over the years.
I have 4 gallons of Blendzall Green Label oil. Can I use it in this outboard?
#460 "Green Label" 2-Cycle Racing Castor
    The "original", formulated from the cleanest-burning castor. Blends with gasoline or methanol to provide sustained performance at high internal temperatures and RPMS. Contains a rust inhibitor and seal preservative. Seperation may occur with some gasoline in temperatures below 50 degrees Farenheit. Add 2 oz. #490 Power Booster to one gal. gasoline to eliminate seperation.
Nope, not good for outboard motors that run anything but wide open throttle. (racing)
Never heard of it before, had to go look it up,
I never know what I'm gonna learn around here.
http://members.tripod.com/matt_87/products.html
I don't know enough to comment.
Castor based 2-stroke is not good to run all of the time, unless u like to do top-end jobs..  I'll run it every once in a while, a little more carbon build up than synthetics, but it smells, oh so good.. ;D
You should pack that nasty stuff up and send it to me ... LOL
I run quicksilver 25:1 for 12 gallons for break in
Dave
I use it in my model airplane engines....
I bought a set of floats for one of my planes so I can fly off the water and after I crash I can go get it with my new skiff...... ;D
Hmmm....
Brand new outboard, run it extremley LEAN, after break-in run it rich at 100:1 fuel/oil ratio.
An interesting read....
http://dirtbike.off-road.com/dirtbike/article/articleDetail.jsp?id=400487
http://mercuryperformance.com/news/latest/break-in-procedures-for-2-and-4-stroke-outboards.html
New 2 stroke engine...run oil rich.
Double regular mix first 10 hours.
Discussion Starter · #10 ·
I also used some CRC Di-Electric grease in the squeeze cheese can and shot a dab in the spark plug boots and all of the wire connectors one at a time.
The wire connector boots are well made but there is no grease to protect the plated connectors. Hopefully the grease will also protect the copper wire and keep salt/water from corroding the wire(s).
http://www.crcindustries.com/ei/content/prod_detail.aspx?PN=05105&S=Y
1 - 10 of 10 Posts
