As far as I know, HDPE can't be bonded together aside from using fasteners.
I need an inch of thickness to replace the rotted plywood in a 1950's Lone Star Corsair. It's a very light aluminum semi-v boat, brochure says 150#. Transom is 15" height, with the strength section being 9"x48", 1" thick.
I have some 1/2" HDPE sheet that I can double up. If I were to thru-bolt it to the aluminum sheet of the transom, would it have enough rigidity to take the force from a 20HP motor weighing around 100#?
Bonding with glue or epoxy isn't possible. But in order for 2 stacked sheets to flex, there would need to slippage between them. If there are bolts installed in precisely drilled holes(not oversized), the lateral movement between the two sheets would be eliminated unless the holes elongate or the fasteners shear.
I'm thinking 24-5/16" bolts, fender washers on each side, evenly spaced along the transom board.
Waste of time or give it a shot?
