No Clue! lol Was kind of thnking id use marine ply for stringers and transom. Then maybe a honey comb for the decking? Still researching alot to see what i can/should be useing.Should be a fun project! Have you chosen any materials yet?
Thank you for the link. I was wondering about how to construct the bulkheads. A quick glance at that thread and it has a lot of good info. Thank you.Lots of inspiration in the bragging section. One of my favorite quick ones for a small craft was:
https://www.microskiff.com/threads/14-rivercraft-rebuild-into-flats-skiff.17276/
Thank you Sir!Be careful with that bottom paint - very bad for you.
You won't need luck - you got all the support you need right here on the forum.
It is a nice simple setup. I just would like to add some coreing, and possibly some foam flotation as im hoping this may be a rig my nephews can learn boating basics in.I used to have a wenzel. Very good little boat. I actually loved the stock set up. I painted it then fished the hell out of it. The rear is already like a small deck
I am removing it from the inside. I did not want to really have to worry about re glassing the outside by taking the transom out in that direction. So the outside piece of glass will still be intact. So inside will be just one piece of glass. Will Make transom template for inside. Cut coosa to fit. Fillet coosa board into place. Let that dry, then glass in from the inside.Are you removing the transom core from the inside or the outside? Did you leave any of the existing fiberglass (as a lip to tie into) on the inside or outside. If so, you need to go back with the same core thickness .
Thank you. That makes me believe i should be fine to do a 1 inch transom with a 20 zuke and maybe a jack plate down the road if needed.The transom that I am in the middle of replacing (hobie skiff rated for 60hp) the core was only 1" balsa cubes.
I actually just came across this idea on another thread. Basically that T is just more of a brace to keep everything sturdy correct?I would make it 1 1/2". Maybe make the 3rd layer in the shape of a T about 8" wide. The difference will not weigh much but will be stronger.
Yes. If you are going to add knee braces it gives a great place to anchor them.I actually just came across this idea on another thread. Basically that T is just more of a brace to keep everything sturdy correct?
