I just upgraded my engine and selling this 1998 Suzuki DT25c 2-stroke 20" long shaft. Runs great and has plenty of life left. It has never let me down. I'm the second owner and have a detailed maintenance list since I've owned it. I'm not able to confirm the total hours, but installed a tiny tach in August 2018 and it had 135 hours when I removed the engine August 2020. Most of the hours are at idle speeds.
-Electric start
-No power trim (manual lift only)
-Comes with remote control & wire harness (does not include control cables or steering)
-Original Suzuki fuel tank (still in good shape!)
-Owner's and service manual
-Lot's of new and some used spare parts (fuel filters, impeller kit, gaskets, etc.)
-The lower unit does have some surface corrosion and paint is flaking off
-A bolt head sheared off in the remote control case, but still able to take it apart and it's held together no problem with the remaining bolts and mounting bolts
-A bolt head also sheared off on top of the driveshaft housing when I lightly checked for tightness while changing the impeller and has been left as is without any issues running it since it happened.
Located in Miami, Florida
Asking $1,500
305-814-1967 (prefer text and then I'll call back asap)
IMG_20200824_082936496.jpg IMG_20200824_082955565.jpg IMG_20200824_082926294.jpg IMG_20200824_082945895.jpg IMG_20200824_082906680.jpg IMG_20200824_083027689.jpg IMG_20200824_083040301.jpg IMG_20200628_152422132(1).jpg
