1 - 3 of 3 Posts
Up for sale is my 1994 15’4” Gheenoe Hi-Sider.
Last spring I gutted this boat to the bare hull and completely rebuilt everything.  There is far too much to list, but a brief overview would include the following:
Decked front and rear with fiberglass over Divinycell cores (no wood anywhere!)
Fuel forward in removable 3 gallon cell
Battery forward with on board charger  (Electrical and fuel in separate compartments and separate conduit)
3 gallon recirculating baitwell….keep those scrimps fresh!
Removable MinnKota 30lb trolling motor
Removable Igloo Cooler/Seat with cushion
Two rod tubes for 9’ flyrods and two flush mount rod holders aft
500 gph bilge pump.
Poling platform it can me moved and secured to the front deck and serve as a casting platform or allow you to pole from the front if fishing solo
Waterproof distribution panel to control nav lights, bilge pump and baitwell pump
18’ fiberglass Stiffy pushpole
2006 Tohatsu 9.8 hp four-stroke:  Purchased new last spring (still has nearly 2 yrs on the warranty).  Approx 12 hours (the first 10 hrs are break-in).  Changed the gear oil, motor oil.  Religiously rinse the engine after every use.  Furthermore, the mileage on this engine is awesome….its burn rate is about a gallon an hour.
I also completely serviced the trailer:  New tires (with 2 spares), new leaf springs, new bearings with buddies.  I will include a spare hub kit (never touched because, like I said, the trailer runs great).  I regularly tow this boat from TN to Florida/Alabama with absolute confidence.  I call pull over for gas and the bearings are never more than lukewarm.
This skiff has an immense amount of storage for something its size.  With a full day’s worth of gear and 400 lbs of anglers, this skiff runs can run over 17 mph (GPS confirmed).
I will also include the myriad other items that are used such as anchor, drift sock, grease gun for hubs, collapsible paddle, etc, etc…
ASKING $3800
Want to know more?  PM me or call Blake (me) at 512-925-5789 and leave a message.
Clearly, only IGFA records are boated on this skiff.
1 - 3 of 3 Posts
