1 - 9 of 9 Posts
I have an Ipb 14 with a 25 yamaha outboard on it. Concerned about the prop because of the numbers I am seeing. My first concern is the prop is "less" than OEM. From what I can make out the only numbers on the prop are 9 1/2 10 1/2 P or something like that.
My concern is the boat weighs around 240# dry hull, by myself (150#) wide open throttle I am seeing around 26 mph. Cruising speed which  I run about 3/4 throttle, is around 22 mph. I feel with this motor and boat I should be at least high 20's cruising if not low thirties wide open.
I am trying to acquire a tach to see the rpm's but for the time being...
Looking to put a new prop on her. Should I experiment with a cheap Solas or just jump to like a 13P stainless? Boat gets on plane in a puddle so Im not worried about that.
Any help is greatly appreciated.
Skiff Skipper,
I happen to have a S/S Solias Prop for a 25 2 stroke Yamaha 13" pitch in great shape, no nicks. $120.00 includes shipping......ran good on my 25 Yamaha. :p
Is that the one I saw you selling for $115? haha What numbers were you seeing, rpms, weight? etc?
That's not too bad. What prop did you end up settling on? You more focused on speed or holeshot? I need more speed than holeshot as I make long runs.
Holeshot, these are 3 blades on a 25. The PT Raised 3" ventilates as it comes out of the hole, boat runs higher and acts like it is on a pad. The holeshot is not as quick as my other skiff with a 4 blade 150 merc, but is acceptable. My thoughts are the Turbo is lots less tweaking to get the max speed, but cannot raise as neglible cup on the blades. Features PT allows owners to return until you get the proper pitch. Turbo does not allow returns on a prop. Prop Gods is a good reference for determining the pitch, but a Tiny Tach is the proper method to arrive at the high end of the rpm range. Three props tried, now to finish the rigging of electronics, running lights, trolling motor, fuse panel... :-/
Sounds like you went through quite a nightmare, just think, the hard part is out of the way (hopefully). Although, the wiring and rigging is a pain in the arse, you'll have a rig exactly how YOU want it.
I wish I had some props to try. I'll have a tach hopefully sometime next week. Do you have a tiny tach I could possibly buy off of you?
1 - 9 of 9 Posts
