Im about to start ripping my Gheenoe down to nothing but the hull and no seats. I am completely new at boat restoration and this Gheenoe is just not set up the way I'd like it to be. I plan on building it as follows with a front casting deck with pvc pipes to store rod tips, one storage hatch for a battery, a trolling motor mount, a rear casting deck near the transom where the bench seat one was with storage underneath for the gas tank and possibly another battery for the power pole micro anchor. Id like to install a false floor with a yeti as a seat or for storage where the center bench seat used to be. I enjoy building things and Im good with tools but I'm just completely new to fiberglassing and painting over fiberglass. By no means am I dead set on these products or methods I'm really just posting this in hopes that someone can tell me what I'm doing wrong and what I should do instead and most importantly what products do I need to buy.
First thing I need to do is sand the paint off. I have read to start with an 80 grit or 120 grit and been told to only sand by hand.
After sanding I've read to use 1/2 inch marine ply or 1/2 inch composite material which I've been told is lighter and easier to work with but I've had no luck finding where to get it from.
Ive done a lot of digging on forums to look for what materials to use for fiberglassing and most forums say to use "regular" fiberglass and epoxy but I am completely new to fiberglass and I have no idea what fiberglass to buy. I'm planning on going to west marine for the fiberglass materials and I've already been to one and the guys working there were clueless. Ill need some fiberglass and epoxy to build a front casting deck, a rear casting deck, a false floor, and to repair small holes and cracks. Ive also seen a lot of people use some type of putty like material to fill cracks and clean up corners. Ill also need some type of expanding flotation foam for coast guard regulations and also to displace water underneath the false floor.
As far as exterior paint and primer I have heard all types of different products but 545 seems to be recommended the most. Most forums on here that I've read tell you to use a paint gun but I am looking to hand paint due to not having access to a paint gun. Id like for it to be grey with possibly a lye rod GOOP IT on the bottom to protect from oysters and random barnacle covered sticks.
As far as interior paint I am planning on using white awl grip with black flick paint over top to hide all of the mistakes and scapes I'm probably going to make in the process. Ive seen on awl grip's website that they make a specialized roller to make the texture right. Is this bullsh$t or do I actually need this roller?
This is not a project that I am rushing into and I will be waiting for some help from guys on here with experience before I start Breaking Out Another Thousand on things I don't really need.
