1982 Mako 224 resto-mod
Discussion in 'Big Boat Bragging Spot' started by LowHydrogen, Mar 2, 2017.
  1. T Bone
    T Bone Well-Known Member
    270
    64
    153
    LowHydrogen likes this.
  2. LowHydrogen
    LowHydrogen Fly-By-Night
    1,090
    1,270
    728
    T Bone likes this.
  3. WillW
    WillW I Love microskiff.com!
    366
    279
    438
    Looking good
  4. sjrobin
    1,388
    751
    718
    Good plan using the wave crusher to get to the big swimmers. I have a friend with a Mako 20 he bought new in 1976. Mako's and Whaler's are the about the only sea worthy outboard survivors out of 70's/80's era. Not sure about the big Merc. Don't leave sight of land.
    LowHydrogen and SomaliPirate like this.
  5. LowHydrogen
    1,090
    1,270
    728
    Back home in FL. Ready to get started back on the project.
    Had some deliveries when I was up North working. Mostly safety stuff.
    Pop up for the bow, high water alarm, secondary bilge pump, float switch.
    SomaliPirate and yobata like this.
  6. LowHydrogen
    1,090
    1,270
    728
    Today I pulled all new wire from the console to the bilge (not fast or easy). Replaced and re-terminated all the switches in the switch panel. Traced down the remaining old wires, labeled, then cut off and eliminated the old fuse/buss. I've never really liked the idea of a hinged console before I started this project, after today I'm really really happy I didn't have to spend multiple hours on my back and working overhead. Still have a long way to go but here are a few pics of the carnage so far.
    IMG_20170524_185747_01.jpg IMG_20170524_183804_01.jpg IMG_20170524_183759_01.jpg IMG_20170524_183753_01.jpg
    ceejkay, Net 30, T Bone and 1 other person like this.
  7. LowHydrogen
    1,090
    1,270
    728
    All of the paint is now stripped, with the exception of the console seat hatch, and the splash well. Removed the storage box from the console and will be flush mounting a bottom machine/gps.
    Progress has been slower due to fishing, when the weather is nice. So the next few days should be good for the boat project. Including a couple recent fish pics for variety, since, let's face it stripping paint isn't interesting.
    sjrobin, T Bone and SomaliPirate like this.
  8. LowHydrogen
    1,090
    1,270
    728
    Also had a delivery this week. 4 new rod holders, and the new rub rail, and compass.
    yobata and Skinny_fly like this.
  9. LowHydrogen
    1,090
    1,270
    728
    Late yesterday evening I broke a shift control cable while trying to force it when I had (unbeknownst to me) got it on a bind during some of my wire pulling. The jacket separated from the end sleeve. So I did a little research last night, located one and spent the first half of today fixing that. Second half of the day was rewiring and reinstalling the trim tabs. The control box and switch are wired in (for testing purposes) but not in the final mounting location. Early on in the project in a fit of frustration I cut the wires to the tabs, causing myself a good bit more work opening the cylinders and re-terminating the wires. Pro-tip don't be like me, when you're frustrated, grab a beer, not the side cutters.
    sjrobin, yobata and T Bone like this.
  10. LowHydrogen
    1,090
    1,270
    728
    Installed and wired the primary and backup bilge pump, new float switch, and rewired the old baitwell pump. Will be installing new hoses on the pumps. Worked on terminating wires at the fuse panel.
    I cut the wire for the bow light that was in a bind but still can't extract it from the chase. Not sure what my solution for the bow light wire will be just yet.
  11. floridascuba
    floridascuba I Love microskiff.com!
    215
    23
    393
    Nice. Once I get my East Cape sold, I want to start on my 241.
  12. LowHydrogen
    1,090
    1,270
    728
    241 is a really nice boat, probably one of the saltiest boats in it's class. My good friend has a 251, similar specs but they don't hold as much fuel as the 241.
    Start a thread about it!
  13. floridascuba
    215
    23
    393
    mine is the deluxe model.
    so the fuel tank isn't big. want to remove all the analog gauges and flush mount electronics in its place, replace the canvas t-top, all wiring and pumps, remove the bow rail. And repower. and eventually remove the antifoul.
  14. LowHydrogen
    1,090
    1,270
    728
    Got all the pumps plumbed today. Installed the thru-hull for my second bilge pump. Terminated a couple more wires. Also received a delivery of new hinges.
    sjrobin, WillW and SomaliPirate like this.
  15. CDL
    CDL I Love microskiff.com!
    46
    10
    83
    Like :)....following
  16. bryson
    bryson I Love microskiff.com!
    556
    468
    188
    I dig the concept -- I had an old Mako 21 just briefly, but it was too much of a project for me at the time. Looking forward to seeing this come along!
  17. Net 30
    Net 30 Soy un Perdedor
    1,971
    598
    968
    Looking good.
    Always a great idea to Double Clamp every hose that connects to ANY thru-hull fitting!
    sjrobin and LowHydrogen like this.
  18. LowHydrogen
    1,090
    1,270
    728
    Update.
    Weather (humidity) had really hampered progress for a while, it's hard for me to stay home and not fish (when the weather is good for painting, it's usually good for Tarpon, {Tarpon wins}). Finally got some primer and top coat on the topsides, and primer and nonskid on the interior. Still need second coat of non skid on the rear floor. Worked some more on the wiring, epoxied old screw/bolt holes. Non skid down on some of the hatches. Installed the rub rail. I decided I would do an old school rope insert in the rub rail, instead of the black rubber it came with, because I think it looks nicer. After I started, I realized why you don't see these as much anymore, what a pain in the ass. It's done and the rope is tight and solid as a rock but man was it time consuming.
    Still to do, hopefully soon....
    Mount rod holders, mount step pads, hook up to main gas tank, more paint, install hinges, install cleats, install keel guard, and a good bit more I'm forgetting but it's getting there.
    IMG_20170624_115433769.jpg IMG_20170625_134932492.jpg IMG_20170628_093626110.jpg IMG_20170628_093607449.jpg IMG_20170628_093707371_HDR.jpg IMG_20170628_093648605_HDR.jpg
    sjrobin, bryson, T Bone and 1 other person like this.
  19. yobata
    yobata I Love microskiff.com!
    1,769
    978
    718
    Looks great! Keep it up
  20. LowHydrogen
    1,090
    1,270
    728
    I ran the boat for a short time, day before yesterday. Ran it about 15 mi, it has a small fuel issue, I'm suspecting the primer bubble, or the fuel pump. When it ran right, it was really impressive, it topped out at a little over 42kts.
    That was according to my Navionics app on my phone, that has been pretty accurate when I checked it before.
    jboriol, sjrobin and yobata like this.
