1 - 4 of 4 Posts
My outboard has never leaked since purchase, I recently pulled the motor(layed motor on correct side up) and rebuilt my Gheenoe. I finally finished and picked the motor up and mounted it on the transom. It immediately started dumping oil from the prop. I figure it is the prop seal but why would it not leak before or when it was laid on it's side? It wasn't a small leak, it drained out in a matter of 1 min.
Thanks
Doubt it's your prop seal. You may have rested your outboard in an incorrect position
and thus allowed crankcase oil to leak into your cylinders and exhaust housing.  :-[
^x2. Is it gear oil or motor oil? If you put some on your finger and smell it you will know gear oil is the most god forsaken smell ever.
Discussion Starter #4
I double checked again, it was on the correct side. I can only assume it was just overfilled a bit and it leaked out that way. The lower unit is still full but I checked the crank oil and it was slightly lower then when I checked it a month ago. Thanks guys
1 - 4 of 4 Posts
