1988 16' Dolphin Super Skiff, One Owner, Well Maintained
Skip the Wait! Save thousands!
Hull:
- White hull, fiberglass.
- 18 Degree Deadrise
- 3 Piece Hull
-Insulated aft port storage
Engine:
- 2015 Mercury Command Thrust 60 HP 4 Stroke (41 Hours). Used ethanol free gasoline only.
- Mercury Warranty Through 11/2020
- Cable steering
- Mercury Vessel View Module. This brings SmartCraft to your mobile device (iOS or Android)
-Racor Fuel/Water Separator
- Top Speed Approximately 32 MPH, depending on loads
Accessories:
- 18 Gallon Aluminum Fuel Tank
- Aluminum stern poling platform
- Fiberglass Pushpole
- Bilge pump, with auto float switch
- Navigation (port & starboard) lights
- 7 Gallon Livewell
- Vinyl Bench Seat cushion
- Black Rub Rail
-Safety equipment
Electronics:
- Lowrance 7ti Touch Charterplotter/GPS Combo, mounted on a Balzout aluminum bracket
- MotorGuide 55# trolling motor, with quick mount/release
- Group 27 Deka AGM Trolling Motor Battery
-Odyssey PC925 AGM Engine Battery
-Stealth Charging system for both batteries.
Trailer:
-2003 Rolls Axle Trailer. Rolls is essentially an all-aluminum trailer. Patented spring/suspension system never rusts.
-18-month-old Carlisle Radial Trail HD 13 “Load Range C” Tires; Bearings/races.
-LED Trailer Lights
The boat is in excellent condition. She has fished Flamingo, Biscayne Bay the 10 Thousand Islands, even offshore on a really good day. Always kept under a cover. Never beached or ran hard. I have most manuals and documents. Boat is located in Naples 34119. (Title In Hand)
$14,500 OBO
Call David: (305) 741-6075
Hull:
- 3 Piece Hull
Engine:
- Cable steering
Accessories:
- 7 Gallon Livewell
- Black Rub Rail
-Safety equipment
Electronics:
Trailer:
-LED Trailer Lights
$14,500 OBO
