1 - 20 of 97 Posts
Ok so, I sold a 17ft center console bay boat that I had put a lot of time in rebuilding a few months back. Now I’ve got the itch again and so mostly out of impulse I bought another project boat. It’s a $400 15ft “homemade” boat that seems to be pretty solid. I bought it with the intentions of making it nice. Sooo, here we go lol
Water transportation Boat Vehicle Skiff Water
Vehicle Transport Bass boat Trailer Jon boat
Table Vehicle Furniture Indoor games and sports Games
Roof Automotive exterior Auto part Asphalt Automotive window part
Vehicle Automotive exterior Roof Asphalt Car
Table Floor Lighting Wood Flooring
Discussion Starter · #2 ·
I’m sanding down and fixing up the bottom of the hull first. I sanded through three coats of pain and some old fiberglass repair and got down to the gel coat. Can I fill in the deep scratches with resin and then paint or do I need to use glass mat as well?
Mostly Harmless
If the scratches don’t compromise the glass, you can fill them. If the glass is damaged, you’ll have to lay some glass in the defect. What was the patch you ground off supposed to fix? Usually big, ugly patches hide big, ugly defects.
Nate
Nate
If you look in the last pic from the transom looking towards the bow, there are about 20 small holes that were patched with a giant glass piece. They are filled with resin and are sanded smooth at this point. Guessing the patch was for “insurance”???
Thoughts on all the holes being drilled, due to delamination between the glass and the core so they drilled holes throughout the delam area then back filled with epoxy?
either way it’s. Cool looking hull and should ride nicely, any idea what plans it was made from?
Discussion Starter · #10 ·
honestly I have no idea what plans it was made from. Closest thing I could find to it would be a hobie power skiff. Does anyone else have any idea?? It has a super thick hull. The transom is about 2.5-3in thick. The area around the holes doesn’t appear to be delaminated. Any other ideas?
I have always loved the looks of those hulls.
I would put at least one layer of glass over all those holes on the bottom, just my 2 cents. I know they are epoxy filled but they make me nervous.
Could always add that layer of glass from the inside and save yourself some fairing time...
Discussion Starter · #17 ·
Pretty cool little boat! Are you planning on cutting out the floor or is it pretty solid?
it’s pretty solid except for one spot but I’m going to make the rear deck bigger and remove the center console soo I think I’ll remove the floor and replace with 1/2in marine plywood so I definitely don’t have any issues for the next 10 years
1 - 20 of 97 Posts
