I have an Evinrude 115 hung on the back of my ECC Vantage. When I run wide open for more than 30 sec I lose 500 RPM....5200 down to 4700. Once I quickly pull back the throttle and then quickly push it back down, it goes right back to 5200 with no problem until another 15-30 secs go by and then I have to repeat the process. The motor is running smooth and on all cylinders the entire time. Any ideas? I probably have less that 15 hours on the motor so I will be calling Evinrude if I can't find an easy fix.
Thanks,
-Miller
Thanks,
-Miller
