13 gheenoe rebuild, therapy for a broken back
3645 Views 19 Replies 4 Participants Last post by  DuckNut
9
First a little about the title, I had a hunting accident, I fell about 25 feet from a tree stand fracturing 6 vertebrae and seven ribs. So with my first 5 thoracic vertebrae fused with Titanium plates and screws. I decided I needed a project to take my mind off of my injury. It needed to be something I could walk away from at any time , since I was not able to work very long at a time. It also had to be something I could walk away from if it did not go well and not feel too bad if it was beyond my capability at the time. I chose a 1981 13 ft gheenoe that was in as bad if not worse shape than I was. So here are a couple of pictures of my victim.
Vehicle Boat Automotive exterior Skiff Jon boat
Floor
Water transportation Vehicle Transport Boat Mode of transport
Vehicle Boat Skiff Automotive exterior Jon boat
See less See more
Reactions: 3
1 - 20 of 20 Posts
I just finished (98%, anyway) a '79 Highsider that was the same color scheme. Similar condition, except my dad bought it new in '79 and had the transom rebuilt in the early 90's. Except for the injury, I did the Gheenoe for a lot of the same reasons you did. Fun little boats.
Reactions: 3
I love the 13 foot gheenoes .
If that was mine I would fix the transom , and install a lightweight "false floor" in front of the rear seat and nothing more ...
don't hack out the center box etc
keep it light , keep the rails and nose cap .
Keep it simple and enjoy it ...
That's my .02 and I'm sticking with it ...
6
In hindsight that may have been a better choice, however it would not have satisfied my goal. It would have been too quick and easy. Instead I did much more, maybe too much more. I replaced the transom, cut out the center seat, removed the foam, and installed a false floor for starters.
Wood Plywood Roof Floor
Boats and boating--Equipment and supplies Vehicle Skiff Boat Dinghy
Plywood Vehicle
Skiff Vehicle Boat Dinghy Watercraft
See less See more
Reactions: 1
5
I then flipped it over and repaired the bottom and repainted it, it was about as battered as I was.
Furniture Table Vehicle Bench
Table Furniture Shade Plant community Grass
Massage table Table Vehicle Car Furniture
Table Furniture Vehicle
Property Table Furniture Bench Outdoor furniture
See less See more
Reactions: 2
6
After I painted the exterior I put a couple of coats of interlux interprotect 2000E primer and 4 coats of interlux VC Performance epoxy on the bottom. I then flipped it and sprayed the new interior with Tuff Coat.
Property Grass Swimming pool Real estate Leisure
Property Swimming pool Grass Real estate Table
Water transportation Speedboat Vehicle Plant community Boat
Property Grass Table Real estate Resort
Vehicle Boat Skiff Plant community Watercraft
See less See more
Reactions: 2
Man, you got a hell of a lot done in 24hrs!!!:)
Reactions: 4
with my back injury it took me about 9 months I figured if I posted pics at the pace I was working it would be about as much fun as watching paint dry
Reactions: 2
Or my build thread lol!
Reactions: 5
I can say that I have enjoyed just about every thing I have seen you post
WoW ! that turned out amazing ! Bring it to the rally it should win a prize !
Reactions: 1
Great work Kamy.
How do you like the tuff coat? What grit did you use?
Reactions: 1
It went on real easy, I picked up a cheap texture gun from harbor freight. The tuff coat has a fine grit. I didn’t realize there were options. I picked it up at Bass pro.
Reactions: 1
3
next I put on new rub rails and nose cap. followed by a grab bar. Then I made adjustments to an aluminum jet ski trailer I had so the gheenoe would fit it. Then I mounted a 4hp Yamaha 4 stroke, I also added hatch covers front and back.
Vehicle Boat Grass Plant community Automotive exterior
Water Room Glass Metal
Water transportation Vehicle Boat Transport Bass boat
See less See more
Reactions: 2
Did you spray the paint or roll/tip it?
Great job
Reactions: 1
the seafoam green awlgrip was rolled and tipped, the vc performance was rolled, the tuff coat was sprayed. and thank you. I would have preferred to spray the awlgrip, but right now my garage is way past capacity
Reactions: 1
5
the roll and tip was easy.in the past I have sprayed awlcraft. This was the first time I have used awlgrip
Vehicle Water transportation Boat Speedboat Boat trailer
Windshield Hood Vehicle Glass Automotive design
Surfboard Vehicle Hood Windshield Glass
Table Furniture Plastic Automotive exterior Games
Windshield Glass Automotive window part Material property Automotive exterior
See less See more
the first couple are a robalo R 180 that I have sold, the rest are of a 17 ft boston whaler that is on hold till I am in a little better shape. In case you couldn't tell I really like seafoam green.
Reactions: 1
That gheenoe would have been a great dingy for the Robalo
Reactions: 2
1 - 20 of 20 Posts
