1 - 13 of 13 Posts
Stripper in my own Mind!
Who's been running this on their 2 strokes? My Yamaha has it posted on the motor that it is the proper ratio but after talking to a few people, many claim it is still too lean and need to go back to standard 50:1. Cut and Creek, feel free to offer your expert opinions. Thx...
Cert. Yamaha technician
I had a 25 yam 2 stroke on my old skiff and i mixed it 75:1.
I figured somewhere in the middle couldnt hurt.
I personally know Yamaha does a LOT of r&d on their motors before letting them go public, and i havent seen a 25hp blow up ever (minus the older 3 cyl models).
I dont think you will hurt it at 100:1 at all, especially if your using good oil.
Now if your using cheap oil... I would 50:1 it.
Hope that helps
Thx for the info fellas. I have only used Yamalube on the motor and the 75:1 sounds a little better. I just like how clean the motor runs right now but better safe then sorry. Maybe I'll try 79:1 ;D
Boozle on...
I use amsoil saber, 100:1. I do mix it a little heavy, probably 85:1. I'm no mechanic, but I've been doing it for about a year and so far so good. It does run a hell of alot smoother, than when I run out and I have to use regular 50:1.
I had a 15hp and ran it 100:1 it had over 500hrs when I sold it and it still was running strong. Anything over 15hp I would run 75:1 or even 50:1 anything under and 100:1 is fine and is acutally better for the engines.
my 90 yami is oil injected 2006 , and that it set 100 :1 from fac.
Your oil injection is variable, it changes as the motor increases and decreases rpm's.
BTW  C90hp Yamaha's meaning non oil injected models are pre-mixed 50:1 ratio.
Straight from Kennesaw. ;)
Creek:
You up at school? Go to the tilted kilt!
Creek:
Buddy the Tilted Kilt and I are one!!! lmao
We also have one in Jacksonville so it's like I never leave! :D
1 - 13 of 13 Posts
