The bow eye "U" bolt has some fiberglass crack around it and wanted to know if I can put marine tex around it then inside out. Then re- drill a holes to install a new bow eye with bracket inside?
Any tips?
Any tips?
Any tips?
How? don't know. Blake's post reminded me of the pix on their site. So figured they would be a good source for info on how to fix it.Any tips?
How did it happen? If its normal use then call Hells Bay. I have heard great things about their customer service. They may cover the repair.
It's normal use and shows a small signs of tiny spider crack around the bow eye every time I wrinched it up on the trailer. It's nothing major but wanted to prevented any futher damage.Any tips?
Sure!...when I get down to south Florida to pick it up then bring it back to Orlando.please post pics of skiff.
Thanks for heads up Jan.You should be able to get that through ant trailer parts supply store. Not sure where in SoFl it is, but I use Dixie Trailer Supply in Oakland Park.
I agree with this being the way to repair it.If you don't take it to pros to have it repaired, here's what needs to be done to do it right.... Bow eyes should have reinforcing inside the hull... If that area's not properly reinforced you'll end up with what you're seeing. Don't even think about MarineTex for the cracks you can see, worry about the structure underneath. These great little technical skiffs were built to be as light weight as possible. In some areas it's easy to be a little too light weight...
At any rate, remove the bow eye, then grind out the existing reinforcing until you're into clean glass, use a hard wood block shaped precisely to fit the inside vee and glass it into place with several layers of glass that extend an inch or two outside the block onto clean glass (that area needs to be sanded down to clean glass - no gelcoat remaining). Once all is properly cured, then re-drill your mounting holes using the existing ones, then carefully seal the drilled holes with either five minute epoxy or fiberglass resin before re-mounting a new bow eye with backing plate ( a thin ss backing plate should come with a new bow eye). Prior to re-fitting that new bow eye, carefully hand sand the surface areas where you've got gelcoat cracking and re-gelcoat them. Once you've got new gel cured out, carefully water sand it out working all the way down to 800grit paper before compounding and waxing. If you've properly matched the color the repair won't be noticeable. If you done the interior reinforcing properly that new bow eye will be a stronger installation than what was originally there. Good luck.
May have been, we won't know until we see pictures...hint-hint.But why wasn't the boat built like this from the factory?
