Whaler build
Discussion in 'Introduce Yourself' started by Floridian1, Jan 10, 2017.
  1. Floridian1
    Floridian1 Active Member
    8
    2
    28
    Started a 1974 13'4 whaler restoration and ended up switching gears and turning it into a fishing boat with front and back casting platforms. Also livewell setup on the port side in the stern. Looking for some advice on what setup I should use for a 13-15 gallon tank. Room is pretty limited but I don't want to cut any corners and do it right. Any suggestions would be appreciated. Thanks !
    bryson and cougmantx like this.
  2. CurtisWright
    CurtisWright Light, Strong, Cheap. Pick Two.
    1,124
    99
    653
    Nice! Not a lot of room on a 13 whaler. Are you going to be running a 15HP? Id stick with a 3 Gal tank. A second 3 gal tank can be tossed in the cockpit for really long runs. A series of 1-2gal jerry jugs can be packed in here and there. If you have a 15hp 4s you will be in the 15-20 MPG range.
    Floridian1 likes this.
  3. WhiteDog70810
    WhiteDog70810 "Mostly Harmless"
    1,583
    187
    918
    I agree with Curtis. I'd use portable 3 gallon tanks if I was in your shoes. With the burn rate of that size of boat and motor, 13-15 gallons of fuel could easily get stale before you could burn it up and you would never run it dry. No one ever seems to mention that it is really good to run tanks dry then completely refill them. With two 3 gallon tanks, you could run one dry up every trip-ish, thereby keeping your fuel fresh. Since you are installing a front deck, could you find space under it for two 3 gallon fuel tanks and battery? The livewell needs to stay in the stern to soften the ride for your bait, but with the operator, motor, fuel, battery and livewell in the stern, you are going to squat it severely. I know that a Whaler is not designed as a microskiff and it might be impossible to get it to float level, but there is no reason to make it draft more than necessary at the transom.
    Cool rebuild. Post more pics. I always liked Whalers. We used my buddy's 15' Montauk as a mothership on a few hunting trips back in college and I was very impressed. It wasn't a speed demon, but it planed easily and safely carried a hellacious load.
    Nate
  4. Floridian1
    8
    2
    28
    Thanks yall, I will probably just keep the 6 gallon and have an optional 3 gal at hand in case I stay closers to launch.But this does give me more room in the center stern to my run livewell pump and keep it in the same area as the bilge incase something leaks. Front deck is built both batteries I think will go up front. To help level out the load. Trolling motor going upfront as well
  5. WhiteDog70810
    1,583
    187
    918
    What is going to counter-balance that livewell when full? Once you find something to counter balance the livewell when full, what are you going to do when it is empty? Few things are heavier to haul than water, so you really can't stuff enough gear in that starboard storage area to balance things out. Cathedral hulls are less sensitive to uneven loads than other hulls, but on a 13' skiff, it seems like it would cause a pretty significant list.
    I like to keep fuel, livewells and big coolers on the midline. A single deep cycle also needs to be on midline IMO. I don't like 12 volt systems, so I would not have less than 2 deep cycle batteries if I bothered with a trolling motor, so they could be on opposite sides of the hull in my world. If you put the batteries in the bow, I've seen recommendations to use sealed gel batteries instead of water filled because they hold up to the pounding better. I guess the plates can fracture in a water filled battery.
    Nate
  6. Floridian1
    8
    2
    28
    Thanks for the suggestions on the batteries. I'll probably just move the cooler around to shift weight. Also when I'm by myself I guess I'll be the counter weight to the livewell.
  7. CurtisWright
    1,124
    99
    653
    Looking at your latest pics, that is going to be a really heavy and cumbersome boat. All the decks and bulkheads are made of coosa, not to mention the original whaler hull is already pretty heavy. I would try to get it in the water with a motor before you progress much further, because you may be cutting a lot of that stuff out. The cathedral hull with all the weight added to the back will require a lot of HP to plane. I would bet $100 that with you, 6 gal of gas, batteries and that full live well that a25hp will not plane. Especially if you add a friend to the mix. You're going to need 40hp and its going to porpoise without a whale tale.
    The boat was designed to have a fuel tank (only) in the back and a driver in the middle of the boat.
  8. Gervais
    Gervais Active Member
    8
    7
    28
    I grew up fishing out of a 13ft whaler (actually 2) with a 40hp 2stoke Merc which fits that boat well. With 2 5 gal cans of gas and one adult it would run a little over 40mph wide open. With two adults and three kids it was more like mid 30s. That was all bare bones bones whaler with a thin wooden bench seat and side console, no batteries and a few rods, a small cooler light. we would make a 45min run out to surf fish and make it about 2/3 back before having to switch tanks. I would recommend at least a 30hp 2 stroke with all the extra weight and hope for high to mid 20s. Just my 2 cents if its worth that much :)
  9. Floridian1
    8
    2
    28
  10. Floridian1
    8
    2
    28
    Not planning on running a 25hp. Hopefully I can get my hands on a 35/40.
  11. Pole Position
    Pole Position Active Member
    30
    7
    33
    Ive got a 40hp on mine and A) yes, it runs like a scalded dog and B) as Curtis said above, you will need a whale tail or trim tabs to stop the porpoising.
  12. Floridian1
    8
    2
    28
    For sure thanks for all the helpful info. Dont they make self leveling tabs???what's a good brand if so?
Loading...
Similar Threads Forum Date
1977 Boston Whaler 13' w/50hp - S FL Microskiffs For Sale Dec 1, 2016
Nicely restored classic 13ft. Boston Whaler Microskiffs For Sale Nov 24, 2016
Restored Classic 13ft Whaler Microskiffs For Sale May 2, 2016
Classic Whaler 11 Redux Bragging Spot Jan 1, 2016
Boston Whaler 11' Microskiffs For Sale Dec 2, 2015
