Chittum 18 prop advice
Discussion in 'Prop Shop' started by jtrev3, Dec 17, 2016.
  1. jtrev3
    jtrev3 I Love microskiff.com!
    28
    4
    93
    New 18 with 60 Suzuki AV (big foot). Current prop is 13.25" 4 blade 17P. WOT is 36 at 5350 RPM. No issues with hole shots. Any advice to get more speed? I believe red line is 6300.
    Thanks
  2. obrientimm
    obrientimm Well-Known Member
    97
    4
    93
    Need to come down 2-3 pitches.
    stephenchurch likes this.
  3. sjrobin
    774
    220
    168
    Did Chittum and company prop the Suk? He should know the best prop pitch for your skiff.
  4. stephenchurch
    stephenchurch I Love microskiff.com!
    485
    32
    403
    Need to be light at the top rpm range...
  5. jtrev3
    28
    4
    93
    Thanks for the replies! I'm planning on trying a 16 pitch 3-blade. That should get the rpm's up and, hopefully, the top end.
  6. DuckNut
    DuckNut Brandon, FL
    4,180
    180
    1,918
    I would bet he tested the 60. But this motor is not a standard 60. This one has the lower of a 90 with low ratio gears.
    I am going to upset the owner...this is not the right motor for this boat. This motor is for a pontoon or a barge, it is not and was not designed for a skiff.
  7. sjrobin
    774
    220
    168
    That's ok. It is ok to learn the hard way. Some people do not heed the recommendations of the builder or ask for recommendations from experienced skiff owners on this forum before the skiff is built/bought.
  8. jtrev3
    28
    4
    93
    It is the wrong gearcase. I took advice from the wrong people. Hal Chittum was "surprised" when he first saw the big foot. So, it's been an adventure to get a prop that works. What I have settled on - at least for now- is a 15 pitch four blade. This prop raised the WOT to about 6100 RPM and 37 MPH. The hole shot is fantastic and the boat grips very tight on turns. Many thanks to Shields Marina on helping me get the right prop. The motor doesn't seem to work as hard now and turns up the RPM a lot quicker. From what I have seen on this and other forums, this is about as good performance as most any 60HP.
    My advise to Chittum buyers is to put on a Yamaha 70. They are getting 45MPH! with the 70. Other than top end speed, this boat performs better than any flats skiff I have been on.
  9. DuckNut
    DuckNut Brandon, FL
    4,180
    180
    1,918
    That is not "FAIR" advice. You have the wrong motor and do not know the performance of the proper motor. You are tainting a premier builder because YOU listened to a guy on the internet over listening to the builder.
    You also have other options for your prop choice. Not only can you change pitch you can change diameter. But whatever you choose you will not get the prop to turn as fast as a non-bigfoot motor because of the gearing difference.
  10. jtrev3
    28
    4
    93
    Wow. Chill!!
    I thought I was clear. The boat is the best performing boat I have ever had the pleasure to be on. It sure isn't Chittum's fault that I bought the wrong foot! The motor advice I received was not from the interent, but rather from someone who should know.
  11. DuckNut
    DuckNut Brandon, FL
    4,180
    180
    1,918
    The inherent tone of your comment "my advice to Chittum buyers is to put on a Yamaha 70".
    This is what I was referring to. You can't fairly make that comment because you have no idea how the 60 works. That's all, nothing more.
    Now, had you put the correct motor on then the comment could be a fair statement.
    I have no affiliation with Chittum in any way, shape or form, never been there, never met them, nothing. But I feel Chittum builds a great product and I would expect someone to do the same to me if I had said to put a 90 on it. Without the right motor you will never know how it performs with a 60. Without personal experience the opinion has no merit and does more harm because people surfing the web won't read the entire thread.
    That is all I want to convey.
    sjrobin likes this.
  12. stephenchurch
    485
    32
    403
    Woa!!
Loading...
Similar Threads Forum Date
Chittum Skiffs, Rigging staff members needed. The Commercial Zone Nov 26, 2016
Chittum on Boat Trader---not mine Microskiffs For Sale Sep 24, 2016
Chittum yachts General Discussion Apr 19, 2016
2009 CHITTUM ISLAMORADA LEGACY - $37K Boating, Fishing and Marine Products for Sale Mar 27, 2016
Chittum skiff - Islamorada 18 Boating, Fishing and Marine Products for Sale Feb 15, 2016
