Battery recommendations
Discussion in 'Power it up with Electronics' started by manny2376, Jan 5, 2017.
  1. manny2376
    manny2376 Well-Known Member
    17
    2
    328
    Calling on the collective microskiff brain trust...
    Currently running a Wallyworld 24 series as my starting (625 cranking amps) and a Cabela's series 27 (100 amp hours) for my trolling motor. Boat is a shadowcast 18' running a Tohatsu 30 and a 55lb minn kota.
    Would like to maintain the same specs, but ultimately drop some weight. Lithium is outta the question. Just hoping to hear some real world recommendations. I've been reading threads for the last few hours and they go everywhere on this topic.
    Thanks!
    Rollbar likes this.
  2. devrep
    devrep Well-Known Member
    1,381
    171
    918
    optima bluetop D34M.
    Smackdaddy53 likes this.
  3. topnative2
    topnative2 Well-Known Member
    1,900
    74
    903
    I run one walmart 29 series combination deep/starting battery for years and never a problem or even a close one. However, I do not use the TM hours on end like the bass boys do
    Rollbar likes this.
  4. Travisloyd07
    Travisloyd07 I Love microskiff.com!
    47
    3
    83
    Run a lawn mower or motorcycle battery for the motor. The trolling motor battery all depends on how much you troll. You could switch to a group 24 or a optima 34DM or a lot of people that don't troll to much (maybe half the day rather then most of the day) use a 55ah battery.
    topnative2 and Rollbar like this.
  5. manny2376
    17
    2
    328
    Thank you for the recommendations gentlemen. The Cabela's battery is definitely overkill and weighs in at almost 70lb. Probably going to swap that out with either an Odyssey or an Optima (50-60ah more or less).
    Anyone know the required CCA (cranking amps) of 2013 Tohatsu 30hp 4 stroke. Having trouble finding it in the Google.
    Thanks!
  6. Rollbar
    Rollbar Active Member
    132
    22
    43
    Not 100%b sure but memory tells me that Sears Premium or platinum battery is made by Odyssey or one of those top battery MFG, check it out, might be cheaper.
    Just a thought,
  7. Rollbar
    132
    22
    43
    What motor/size etc are you running/starting?
    I was thinking of doing the same thing.
  8. topnative2
    1,900
    74
    903
    If your a hard TM user, the lawnmower/atv battery will give peace of mind.Just mount it close.I forgot about that option.
    i have not heard good things about Optima from sales people.
  9. Smackdaddy53
    Smackdaddy53 I Love microskiff.com!
    267
    153
    168
    The old Optimas that were made with new lead were great, the new ones "hencho en Mexico" are made from recycled lead and do not last like the old ones.
    Most people don't realize that all batteries are made by 3 companies from what I understand.
  10. Scott F
    Scott F Active Member
    7
    1
    28
    I just had the same question, trying to do the same thing except with a 35hp jet motor. My dealer called Tahatsu and they said my motor required a 1000cca battery. A small battery will not have enough juice and will fry the computer in the motor.
    Rollbar likes this.
  11. topnative2
    1,900
    74
    903
    1000cca-----Cold weather specification
  12. Travisloyd07
    47
    3
    83
    I'm running a 2015 Yamaha 20 hp 4s. I'm running a interstate ytx20HL it has 310 cca. I've never had a problem starting. I currently run a deep cycle group 24 because it come with it but after it goes bad I'm going to try a 40ah battery. I don't troll very much.
  13. DuckNut
    DuckNut Brandon, FL
    4,180
    180
    1,918
    Not buying that. Very few car batteries even have that amount of juice. In the big diesel trucks, they put two batteries for this reason.
    Rollbar likes this.
  14. Scott F
    7
    1
    28
    I was looking a group 24 battery that the dealer uses in most of his boats that was 1000 cca
  15. devrep
    1,381
    171
    918
    1000 CCA is for cold climates. for warm climate its 100AH or 850CCA per Tohatsu. I have a 50 TLDI and I've been using an Optima bluetop D34m for 80 hours with no problems.
  16. Zika
    Zika I Love microskiff.com!
    136
    25
    103
    I must have gotten a pair of the Mexican-made Optimas then because they sure didn't last long. Used a pair of Odyssey in the BT and they held up great.
    I rigged up a solar charger for the trolling motor battery and it tops off the charge so it's ready to go every time. Charger has a regulator so it can't cook the battery. Have about $160 invested in set-up but all my juice is now free.
    Using a MG Xi5 55-pound thrust and have yet to run it below 3/4 level.
  17. Rollbar
    132
    22
    43
    WalMart Marine deep cycle, lasts years for me and cheaper.
    I wonder what we used before all these fancy batteries came out.
  18. DuckNut
    DuckNut Brandon, FL
    4,180
    180
    1,918
    What brand would this be for the 24 size?
    Optima is only 800 for a 27.
    Deka, Interstate, Duracell, Odyssey, Wally World, Sears, don't have them.
  19. FSUDrew99
    FSUDrew99 Well-Known Member
    274
    20
    143
    I just swapped my Optima Blue top 34 series for a 27 series for my 60 hp etec. The guys who service them in town recommend a battery that has 1000 MCA not 1000 CCA, mine has 800 CCA and 1000 MCA and she fires up like a champ. Cant go wrong with the blue top having that much power plus being a dual battery is nice to run speakers, electronics etc.
    Pay a little more for the battery and do it right the first time. Plus they have a 3 year warranty. Got mine at Auto Zone.
  20. Blue Zone
    Blue Zone I Love microskiff.com!
    485
    138
    418
    I am pretty sure the engine manufacturers overstate the required CCA and the battery manufacturers understate their CCA number.
    I forget the numbers, but I put a Odyssey 925 in my son's Whaler for a 20 4S and it works fine. As I recall the Odyssey was well below the recommended Merc CCA, but my thinking CCA in FL is meaningless most days.
Loading...
Similar Threads Forum Date
Island Hopper Kayak trolling motor, bracket, and deep cell battery FS Boating, Fishing and Marine Products for Sale Jan 2, 2017
Blue top optima D34 battery for sale - $65.00 Boating, Fishing and Marine Products for Sale Dec 10, 2016
Island Hopper kayak trolling motor, bracket, deep cycle battery FS Boating, Fishing and Marine Products for Sale Dec 2, 2016
Single battery for trolling motor and engine? Power it up with Electronics Sep 25, 2016
Charging trolling battery thru plug Power it up with Electronics Sep 12, 2016
